Farmall Super C Valve Caps neede
Hey Ya'll,
Does anyone know where I can purchase the caps for a set of valve springs. I ordered a valve train set and the kit comes with springs, keepers, guides and valves. I have missplaced the caps and have looked everywhere. Awwwwww
Thanks
Do you have 8 identical springs, or 4 exhaust springs for use with Rotocaps and 4 standard springs?
Bob's question is important in that exhaust valve retainers (caps) may , or may not be rotator style. Different springs were used
for the rotator retainer. Getting a set of non rotator type (8 the same) would allow the rotator spec springs to be too short for
proper tension. Jim
I had no ideal. Now that I think about it, there were four different springs and spring caps.
Thank you guys sooooo much for that information.
Ok so I have been looking for rotator type valve train kit and can't seem to find a set. Can someone point me in the right direction please. Maybe a picture! Thanks
Sir, If I order a whole new valve train set for this Super C, will the new valves work. I guess I would probably need new valve spring caps.
