New Farmall H owner. Trying to identify and find new tube fittings on the crankcase vent tube connecting the rear of the cylinder head to the air cleaner housing. Cyl head fitting with the orifice is fine as well as the fitting on the air cleaner housing. The tube side fittings look like inverted flare nuts in brass. Thread pitch is 20. Diameter is 9/16. I am having a hard time finding such brass fittings. I thought initially they were British threads, but the fitting/hose suppliers say different. So far, I can find a steel brake line fitting they may work if I drill it out the center for the 3/8" tube. Any suggestions? Sources? I would say its original tubing. I need to make a new tube as I found a hole in the tube end near the cyl. head end.
The tube assembly consists of a 3/8" tube, compression sleeves on both ends with the inverted flare type nuts screwing into each end fitting (Cyl. head and air-cleaner housing). Tough to replicate so far.
