Melroe chisel plow
DTK
Hi, I have a Melroe high clearance chisel plow. I am looking for the coil springs on top of the shanks. They are 14" long x 3" dia. If anyone you
has any info. on them I would appreciate it. I am in Mn. It is the later mo. Chisel plow mo. 510. Thanks DTK.
Will a regular chisel plow spring work,I know where this is a 27 foot used one, sitting on a vaccant farm near Kulm, North Dakota. Your going to need the cap also that goes on top of the spring,are you not? But you might have to buy the entire machine. That was a Geisler Mfg,out out of Montana, not sure of the city! Post this ad under Implement Ally, we will talk more!
(quoted from post at 09:18:43 10/13/18) Hi, I have a Melroe high clearance chisel plow. I am looking for the coil springs on top of the shanks. They are 14" long x 3" dia. If anyone you
Try calling Rick at the number below. At one time, at least, he had parts for the Melroe drills and MIGHT have some info on Melroe tillage parts.
Worst case, you're out a phone call!
(701) 327-4436
(quoted from post at 15:18:43 10/13/18) Hi, I have a Melroe high clearance chisel plow. I am looking for the coil springs on top of the shanks. They are 14" long x 3" dia. If anyone you
Sorry, the correct model # is a 551. Thanks DTK.
