Company Logo Shop Now
TractorLinks.com
Farmall 100 starter not engaging
grampsh1
10-12-2018 09:23:28
New battery tractor started well tractor has set for couple months went start today pulled starter switch nothing half turn with hand crank running starter switch new year ago thinking corroded contacts in switch what can I put on contacts after polishing to prevent ground connection from battery cleaned when battery changed any other suggestions if not switch starter rebuilt a year ago
grampsh1
10-13-2018 09:58:30
 Re: Farmall 100 starter not engaging in reply to grampsh1, 10-12-2018 09:23:28
Quoting Removed, click Modern View to seeremove band covering brushes on starter commutator very dirty removed starter disassembled polished commutator brushes fields on stator lubed removed switch on starter holes were already elongated but contacts corroded polished all contact points wire wheeled all contact points of starter case before reassemble and bell housing contact point cleaned both ends of battery cables and battery posts put all back together and presto starts like brand new thanks for all the suggestions really appreciate the support Paul
grampsh1
10-13-2018 05:00:02
Quoting Removed, click Modern View to seethanks for suggestions I will try all these and reply back
c.amick
10-12-2018 17:26:38
Make sure the battery cable ground connection is clean at the tractor body.
Janicholson
10-12-2018 10:57:00
The switch may need its holes ovaled to allow it to touch the lug. Jim
rvirgil_KS
10-12-2018 10:14:09
Check and clean both ends of both battery cables. Connections must be clean and tight. If cables or clamps look corroded replace them. Tractor end of the ground cable should go to a bolt on the main frame as close to starter as possible, not through rusty battery boxes and sheet metal.
