CenTex Farmall
Being that early 560's came with the band type PTO and later changed to the clutch type, can one install a clutch type PTO in 450
and lower machines? I see that the mounting bolt pattern is the same but what I don't know is the length/spline count on the front
end.
Is it also possible to install the PTO speed reduction gears from a 560 into the 450? Would one need just the gear set or the
intermediate shafts as well?
end.
