Farmall 300 rear hydrualic lines
Anybody know of anyone who sells or repairs farmall hydraulic lines. I have a 300 that had a pinhole rust thru on the lines going to the rear fast hitch cylinder. I got it off and we welded up the worst pitted places but given as much trouble as it was to remove from under the dash I'd like to buy a new set or have the blocks re-tubed so I don't have to go thru pulling it off again in the future when another pitted place blows out. Thanks
So was that sitting with he valve cover off, that's what it looks like to me,I bought a tap and die set that was in the original plastic blow formed container, a little water got in there i had to use the[1/3 horse] wire brush on each piece to get the rust off!
I know it's not approved by the correct police but the tube is usually still good on the vertical part so I will cut the line and use a nut and ferule and run a hose to the rear.
A number of years ago I needed the lower tube for my 350 Farmall, I went to a Hyd tube bender and had some made up. If the tube you need is the lower one. I can sell you what you need. The old tube can be heated for removal and the replacement is silver soldered in. Charlie U
