M pto gasket
fred kobs
Hey guys, was hoping somebody had a to scale picture of the gasket that goes in front? back? of the pto seal/bearing retainer. Just flushed the rear and filled with new, expensive gear lube. naturally in the dark corner of the shop after i installed the new pto seal i got the housing upside down. went to flip it and tore the gasket. now i need to replace the gasket and can't watch $ run out of it whle i cut a gasket. Thanks in advance for any help. and if you find this funny, please dont share, i will also probably chuckle about it later, much later. thanks again. Fred
just came in from doing just that scott. thanks. had to add a couple blocks to the idea tho. it came to me about 10 minutes after the evening beverage. Reds, I don't have the strength i did as a less old guy, 2nd heart attack fixed that. takes me forever in a day to get things done anymore. anyhow its sealed up and under a roof now and the road is almost dry so it can rain about daylight. hasnt rained here for about 36 hrs now so we are due...
