Gas line leaking farmall H
On my farmall H the gas line going into the sediment bulb is leaking. The old fitting was leaking so I put a new one on. it slowed the leak from a drip to the line just being damp with gas not drip is there something I can use to seal it off. thanks for any advice.It is as tight as it can go without stripping something.
If you think the threads need to be sealed, they make a gasoline proof thread sealer compound. I bought some at an auto parts store.
