Is this tractor open or close center hydraulics?
What is the GPM of the system?
Any idea what the correct model 12v hydraulic valve is that can be controlled via laser for grade work that is compatable with this
system? My first attempt failed with the valve I have because the box blade would not raise fast enough to hold grade and would
lower to fast, so I blame the control valve is not proper?
TIA.
TIA.
