I needed to replace the radiator on my F-450 and went further cleaning, painting and replacing fluids and gaskets. In the process, I pulled the hydraulic pump. I believe it is an M&W pump installed by a prior owner. As seen in the photo, the lines were run to the top side of the pump.
I don’t believe it is a problem, but thought I’d ask here - can the pump be rotated 180° so the lines are at the bottom? I need to replace the flexible lines and wanted to follow the path original to the tractor.
