Roger Tomfohrde
So I have working on and off on this 560 trying to get the power steering working. Changed pumps, gaskets, O-rings and even split the thing to replace the one in the middle. Today I put a valve on the pump to check pressures and found it I think lower than what it should be but the transmission was making the oil foam because of being low. Corrected the low problem but the pressure only came up to around 700 at idle, may still have foam. I decided to look into the valve on the front and I think it is junk because the spring was part way out of the washer on the nut end. I tried to get the nut off and it just spins the shaft and the clevis stays still. How do you get it apart or should I just replace it? I can hear the pump relief open.
