Bucket control valves
hotrodseth
New User
Just wondering if anyone on here knows how to rebuild the spool valve I have pictured. Not sure what it is exactly, I don't want to rebuild the whole thing but just what is leaking bad right now which is on top between the output hoses. I have take the snap rings out but the piece won't come out it pushes down a little and moves so it's not locked up. I'm sure there is a seal under it somehwere but how do you get to it?
with a thick rag and engine running, just bump the valve lever, should pop it right out. Don't hold the lever just lightly bump it with your hand or arm.
