Company Logo Shop Now
M400 'frankentractor.
DeltaRed
09-28-2018 07:12:31
In response to Barnyard's earlier comments.The M bolster was broken and welded,the side rails were welded to the bolster as well. The Md radiator is junk,so using the 400 radiator as I don't want to spend a lot of money on a new radiator. the MD flywheel was stolen,so the 400 flywheel.I needed a hydraulic reservoir,hence the 400 reservoir.The 400 came off a dairy.Their loader tractor. it is rough,it has had the liveing crap beaten out of it.The motor was rebuilt(with a new clutch) shortly the transmission went south.The TA had been out for years,a rear axle was wallered due to a rear wheel being loose for a long time.Something poped in the rear and it quit.A rear wheel is cracked,smooth tires.then it sat for 10-15 years.The MD sat on the side of a mountain at 9500 ft for 40 years. So we are going to have a hodge-podge.I really don't care,as I'll have a running tractor instead of two junkers in the 'dead row'.
scott mcintosh
09-28-2018 13:46:18
 Re: M400 'frankentractor. in reply to DeltaRed, 09-28-2018 07:12:31
Delta Red I have many items here where I made something from two three or more piles of goodies.Having made something from when dollars were short give you the mother of invention.Charge on and you will have something.Scott
old
09-28-2018 11:11:47
Pretty much what I did to make my BA. 2 parts Bs and a parts A and now I have a good running BA. Front from a B block from a B engine parts from the A and transmission/rear end of the A. Has a A-16 sickle mower on it and the mower was why I built it
BarnyardEngineering
09-28-2018 11:10:17
WHERE are you getting that I am a "naysayer?"
I've only said, THREE TIMES now, that it will be EASIER than you think it is. You've made out that this is some large undertaking. It isn't.
*DO* it!
I don't think I can put it much more simply than that.
DeltaRed
09-28-2018 18:36:58
 Re: M400 'frankentractor. in reply to BarnyardEngineering, 09-28-2018 11:10:17
I AM doing it. Almost done......Hook up hydraulics;wire/ignition system;fabricate throttle;hood/tin work.
moll
09-28-2018 09:54:19
Sounds like if that M was a dog we would call it Lucky.
Janicholson
09-28-2018 09:33:42
Perfect rationale. Nay sayers are a bit too blueblood. Jim
Hayfarmer
09-28-2018 08:05:29
Sounds like a great and worthwhile project.. Sounds like you are saving 2 tractors from the scrapper and coming out with a good running one to boot.
Today's Featured Article - ... [Read Article]
Latest Ad: Front hydraulic pump for loader .. drives off tractor front. Mount bracket included. Greisen brand which is my favorite brand for hydraulic controls. This is use some, then removed and stored inside for several years. Can ship send along your zip for rate. thanks [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
