Ellis Kinney
I am replacing the front wheel bearings on a Farmall M. Pretty easy job for a change. I am currently waiting on bearing kits from Case/IH. I bought from them because it is the only place to get the grease retainers that keep the grease from filling the wheel cavities. The wheels are the old style that clamp on like the rears. Anyway, if you will look at the pictures I have 2 options. The tractor had the extension pieces through the bearing covers, I think for a corn picker???? If I use these I will have to get new seals and probably ready sleeves, If I use the yellow bearing covers I can saw off the extensions and just use the bolt part to hold the wheel bearings. Ideas and suggestions?? Thanks Ellis
