Re: Question on Delta red’s Frankentractor
D Slater
09-26-2018 07:54:38
third party image
Going to run into problems with the 400 starter. It will bolt on the MD housing but a MD housing places the starter gear a different distance from the flywheel gear. You using the 400 pressure plate with a 11 inch MD clutch disc? Rod from clutch pedal may end up short. Yes fuel tank needs raised a little to put a 400 reservoir under. Mounted one on a M with mods and doubled with the belly unit for more oil capacity.
