Re: Question on Delta red’s Frankentractor
DeltaRed
09-26-2018 07:26:53
400 gas engine to MDiesel rear end. I had to use the 400 clutch,flywheel,starter, 400 bolster and radiator,400 flywheel,400 hydraulic tank.The mD had a belly pump,the 400 had live 'mag' pump,with the steel lines. ThenI needed a reservoir,didnt want to use the belly pump as a reservoir.The tank required the gas tank be raised. there some (surpriseing) differences that I am learning... I thought it would be just a simple parts swap.Maybe both tractors should have been hauled to the scrapper? Nope!
D Slater
09-26-2018 07:54:38
 Re: Question on Delta red’s Frankentractor in reply to DeltaRed, 09-26-2018 07:26:53
third party image
Going to run into problems with the 400 starter. It will bolt on the MD housing but a MD housing places the starter gear a different distance from the flywheel gear. You using the 400 pressure plate with a 11 inch MD clutch disc? Rod from clutch pedal may end up short. Yes fuel tank needs raised a little to put a 400 reservoir under. Mounted one on a M with mods and doubled with the belly unit for more oil capacity.
