Company Logo Shop Now
58 IH 130 Industrial
58IH130
09-25-2018 13:17:24
I just acquired this tractor from my father. It hasn't run since 1995. I don't have a large budget, just want to get her running. I pulled the gas tank and zenith carb. Looking for recommondations to clean the varnish out of the gas tank. The carb is really bad shape, looks like someone rebuilt it and didn't use the proper parts. My question is this. I see knock off cheap carbs on ebay, would one of these work? If anyone has suggestions on how I should proceed in bringing her back, I would be grateful. thanks in advance!
jeffcat
09-26-2018 18:40:23
 Re: 58 IH 130 Industrial in reply to 58IH130, 09-25-2018 13:17:24
Simplest way to clean your tank is go buy a few gallons of E85 gasoline. Wow does that stuff eat up the crud in your tank. Keep in away from rubber and paint. It will eat that up too. I have cleaned several gas tanks, and several old kerosene lamps with E85.
BarnyardEngineering
09-26-2018 05:23:24
Gasoline works to clean out the tank, especially with ethanol.
Buying a new carb doesn't get you out of adjusting it for proper running, which is the main reason most people think buying a new carb is better. If at all possible, get the correct kit and overhaul the original carb.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: I am looking for a front grill for a deutz-Allis 7085 [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
