Farmall M oil pump
I?ve read from other post about resurfacing the plate on the
bottom where the gears sit and making sure the valve is good.
So I I took my oil pump off my tractor and noticed that the
shaft on the pump is wore enough to make me feel like it
needs replacing. I can not locate anyone that sells the shaft
not even CIH. I also read about some of y?all making your
own shaft and without a decent machine shop close would
anyone consider making a shaft to sell?
Well it's going to cost a bit to have a machinist to make one from scratch, i know a couple of shop's that could do it,but at $80:00 @ hour. Is the spiral gear, that drives it good ?
Yes I noticed that bates had a reman whole pump unit for an M that was 495 with 100 core refund they must be getting the shafts made from somewhere?
