Hi all;
I have an IH 666 with the year-a-round cab. I was using it to raise plywood for a new barn roof, backed up a bit and bent the door. I did minimal damage, but the door is now very stiff when nearly closed. It appears there is a brake of some sort in the door mechanism that I damaged. I don't see how to get at the internal parts. Does everything come out if I take off the handle mechanism? Can I get there at all without cutting out the metal around the handle?
Photo attached, if I do things right...
Thanks,
Jim
Thanks,
Jim
