Mark Poss
Just had carb cleaned up new brass float and needle and seat. Starts and idles fine but when you throttle up it starts falling on its face. Then it will recover and fall on its face again, I've tried adjusting the knurled knob on top but it doesn't matter. I can turn the knob all the way in and it will still run or all the way out no change. Any ideas? Thanks, Mark
I would go with what Loren said first, I suppose the hole in the lower part of your
center tube is open? Those are more or less mixers, should be able to make a big difference
on the load adjustment.
