Dave Westlund
I purchased this tractor knowing the camshaft gear is broke. I have read that the older camshaft gears were weak when using a LH pump. I'm thinking I would like to get the engine running again versus parting it out. I should be able to find a used upgraded camshaft gear.
I'm not real technically skilled on tolerance/fit stuff. With that being said. Does this just require to pullout the broken gear and replace it? I'm thinking it's not that simple to do it right. I have no immediate need for the engine so it most likely be sold but I'd learn something in the process with the repair.
I would greatly appreciate your thoughts on this.
Dave
Dave
