Gary Mitchell
I'm tinkering with my row crop 350. I took the seat/battery box off it. There is a pair of lines running to the back to where the fast hitch would have connected to the hyd system if it had a fast hitch, which it doesn't,(rolling drawbar). These lines run into a rectangular shaped body that's about twice the size of a cigarette pack. The valve body,(?), bolts to the battery box at the back, bottom, right side. When I took it off it came apart into 2 separate flat pieces. I put it back together and snugged up the bolts but it still seeps fluid. Did I lose a little O-ring? Do I need to make a new gasket? Help?? Thanks, gm
