I’m working on a BN it’s 6 volt has the original wiring set up. When it’s running the amp gauge gets pegged out at anything over idle. There was some water on top of the battery like it was overcharging but I went to start it today and the the battery was real weak but it started I put a volt meter on the battery when it was running at full throttle and it read 8.3 volts idle it down and it read 6. Then when it was shut off he battery would read 5.5 and bounce around to 6.5. I’m thinking the battery may be bad? I did try and move the switch for the lights and the charging rate but that didn’t make a difference
