Farmall 560
Seems like I use to be able to search this site so as not to re-ask questions that may have already been asked and now not finding a search bar. I just got another row crop 560 and do not remember where to check or add power steering fluid?? Any help very much appreciated in advance.
A 560 doesn't have a separate power steering 'reservoir'. It gets it oil from the rear end housing. The main/primary/only hydraulic reservoir. There is a level check plug on the left side ahead of the clutch pedal. The add port is a triangular plate to the right of the shifter lever.use HyTran or equivalent. You need to buy a book.
The "Classic View" doesn't seem to have a search bar or a search function that I can find.
But if you click on "Modern View" there's a search bar at the top of the screen, right in the middle, where you can type what you're looking for and search for it.
