sattlerfarm
New User
Just acquired a 1967 Farmall 706 German diesel tractor that is in pretty good shape, 4500 hours. The tractor sat for 20 years. New batteries installed, and oil/filter changed. Starts and runs good other than some exhaust slobbering. The main problem is it will not shut-off. Pulling the Tee handle slows the idle to a very low RPM, but will not kill the engine. The cable is properly adjusted and pulls the bottom lever on the Bosch rotary pump just fine. This lever moves from it's full forward (Run) position to a vertical position, and rearward to the (Start) position. The fuel should be shut off and thus kill the engine in the vertical position, but it does not. The lever is properly attached and appears to be working fine as viewed from the outside, so the problem must be internal. Fuel is bypassing the shut off inside the pump. What do you think? Bad seals that can be replaced easily or is this a rebuild by an injector shop? Thanks
