Rar wheel bearings, on a H
GregtheDC
Have done as suggested on here and listened to the rear wheel popping on the left side of my H. All lug nuts are tight and can fell a pop in my hand when holding it on the tire when rolling it across the floor by hand. Have to order a repair manual but curious how hard is it to replace the wheel bearings, since it seems that might be where I am headed?
THanks to all for help
Greg, hold the phone, take the rim off the wheel, hope it doesn't have fluid in it,I had the same thing on my SMTA,what it was the drive lug on the rim is riveted on by two big rivets, the head, or the squish part, of one rivet was touching the riser in the cast wheel,all i had to do was to go in and grind on the rivet head a little,what changed or why it started,i cant explain that, but that made noise for me, during two differn't plow days !!
Bearings don't often Pop when they are failing. They rumble or grind. A pop is probably a rim to wheel clamp. put a dab of finger nail polish on each (both inside and outer clamps, let it dry and drive it. shattered paint is a giveaway. Don't just tighten, loosen and retighten!! Jim
