Company Logo Shop Now
F20 Governor Issue Revisited
Ken Christopherson
08-12-2018 12:27:00
Hello all! A while back I posted about some governor issues I was having with my '38 F20 - it seemed that there was no mid-range throttle, but only idle and then when advancing the throttle, you would get to a certain point and the engine would jump to 2/3 or full throttle. I tore it down some to inspect some parts, and it seems everything is moving freely, and does not seem to be hanging up on any shafts or assemblies. (Keep in mind I am working without a manual or exploded view diagram here)...
What I did notice is that the governor weights, on one side, had a cotter pin through each and a spring connection the two weights, so as to keep them in the closed position. The other side of the weights were drilled for the pins, but the spring and pins were missing. I replaced both springs and all cotter pins, and the tractor seems to be operating much better - but, it doesn't seem like I am getting a proper governor response under load. My question is - are these springs supposed to be there, or did someone add them at some point for some reason. Seems to me the weights should be able to move freely, only being regulated by the thrust bearing. Any ideas? I have included a video that shows the work I did (skip to about 24:40 in the video)... All help is appreciated!
robgIN
08-13-2018 18:03:44
 Re: F20 Governor Issue Revisited in reply to Ken Christopherson, 08-12-2018 12:27:00
The variable speed governor should not have the springs on the weights, the single speed governor used the springs on the weights, at least that is my experience on the F-series that I have. Someone may have updated to variable speed setup and not done everything correctly or someone may have tried putting springs back on it for some reason later, almost anything is possible .
Ken Christopherson
08-14-2018 04:24:25
 Re: F20 Governor Issue Revisited in reply to robgIN, 08-13-2018 18:03:44
More than likely I will end up pulling the springs off of it. I am going to see how it does at the show this weekend on the sawmill. If it bogs down and won't kick in during cuts, that is a dead giveaway that the governor isn't doing it's job.
James Williams
08-13-2018 07:07:18
Sounds good to me
Ken Christopherson
08-13-2018 18:00:38
 Re: F20 Governor Issue Revisited in reply to James Williams, 08-13-2018 07:07:18
We will see what happens at the show this weekend. I will belt it up to the sawmill and see what it does. My guess is it will still be kind of sluggish to respond. I will see what I can get figured out while there. Never hurts to turn some wrenches at the show - brings in the crowds, sometimes! :-)
16-30 oilpull
08-12-2018 18:19:35
I can't answer your detailed question on the parts in your gov. I do know that the old style govs were either open or closed throttle. these are usually controlled by a lever on the steering shaft in front of steering wheel. This was on the older tractors and most were changed to after market variable speed govs. Not an expert on this ,but having owed 12-15 of these over the years have only had one of this style.
Ken Christopherson
08-13-2018 04:22:30
 Re: F20 Governor Issue Revisited in reply to 16-30 oilpull, 08-12-2018 18:19:35
This tractor does have the variable speed governor on it. After doing a little research, I think It may be a combination of things - I looked up the governor on google images, and all of the photos of them that I can see, none of them have springs connecting the weights. The second issue I think I might be having is the governor to carb linkage tube is missing the gasket between itself and the carburetor - this can cause binding from what I have read so I will try to fix that issue as well.
I'll let you guys know how it goes - and of course there will be video of it as well!
Fred47m
08-12-2018 16:35:14
Storm creek govs is who i think fastfarmall is referring to. Carrol ia.
Ken Christopherson
08-13-2018 04:20:00
 Re: F20 Governor Issue Revisited in reply to Fred47m, 08-12-2018 16:35:14
Thanks for the info - if I can't figure it out maybe I will look him up and give him a call.
FastFarmall
08-12-2018 16:07:26
Ken, there is a guy in Iowa who is excellent with H and M-450 govenors,His name is Bob Lenze,i lost his number when i lost my phone 3 weeks ago, but he does check in from time to time, So Bob if u see this you can call me too, He would be a great resource !!
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: ford 9n -8n- naa -600-800- 2000-4000 tractors massey fergurson to20 - 35 - 40 -50 -85 - 235 tractors international - 436 eng -706 block and head gas -300 u -464 gas - 240 tri - a - b - bn - 140 -tractors [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
