Company Logo Shop Now
Farmall 140 Top Radiator Hose
K-Mo
08-04-2018 07:53:33
Looking for correct aftermarket top radiator hose for a Farmall 140 (P/N 369397R1).
Most aftermarket 369397R1 hoses do not fit. CaseIH hose IDs are 2-3/8" and 2-1/2". Many aftermarkets IDs are 2" and 2-5/8".
CityBoy140
08-05-2018 04:30:04
 Re: Farmall 140 Top Radiator Hose in reply to K-Mo, 08-04-2018 07:53:33
I have been lurking for a while, but this is one of the first times I have something useful to contribute. :D
I recently went through the same issue after my 1970 140 decided to run away into a tree.
I ended up getting an IH hose from Messicks and it fits fine.
https://www.messicks.com/part/369397R1/hose-238-id-250-id-x-400-sae-20r4-class-r-grade-1
AlinMO
08-04-2018 14:20:43
From YTD catalog:
Farmall 140 Radiator Hose, Upper
Radiator Hose, Upper - Measures 2 inches inside diameter on one end and 2.625 inside diameter on the other, for gas engines. For tractor models 140, 240, 404, 424, 444. (Part No: 369397R1) $10.65
Radiator Hose, Upper - Radiator hose, upper, for gas engine with Blackstone radiator. For 140, 444. One end is 2.25" I.D. the other end is 2.500" I.D.. (Part No: 405111R1) $14.40
You have me confused. Are you saying if you order part #405111R1 (this looks to be the part # you need) that you get #369397R1?
K-Mo
08-04-2018 14:29:15
 Re: Farmall 140 Top Radiator Hose in reply to AlinMO, 08-04-2018 14:20:43
The 405111R1 is for tractors using the Blackstone radiator.
The correct hose for my application is the 369397R1, however, the aftermarkets have the wrong inside diameters.
If the hose was made as describe by CASEIH, it would fit.
Lucid
08-04-2018 13:09:53
When I replaced all the hoses on my 200 couple years ago, I went to Napa and got short pieces to fit. My top hose didn't have a bend so not sure if it will work. Has the c123 engine. Something to consider if all else fails..
AlinMO
08-04-2018 09:31:17
Is this the one you want? On this web site.
https://www.yesterdaystractors.com/Farmall-140_Radiator-Hose-Upper_405111R1.html
third party image
K-Mo
08-04-2018 09:56:26
 Re: Farmall 140 Top Radiator Hose in reply to AlinMO, 08-04-2018 09:31:17
I have sent an email to YT Parts about the problem.
The CASEIH dimensions agree with my tractor radiator and thermostat housing.
It's the aftermarket source that is in error.
Main point is, if someone orders this hose to fit a 369397R1 application, most likely it will not fit.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
Latest Ad: Green magazine back issues for sale, in good used condition, some of the covers have mild chaffing. Have years 1991, 1992, 1993, 1994, 1995, 1999, 2000, 2001, 2004 and 2006 years available. 12 issues per year. 10 dollars plus shipping per year. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
