Re: Farmall B generator bracket in reply to calcubman, 08-04-2018 07:03:41
K-Mo is correct, the adjustment bracket for the generator goes on the top bolt of the water inlet elbow. The top bolt of the water inlet elbow should have threads past the head of the bolt - and the bracket goes on it, with a lock washer and a nut.
Put the one end on the generator and 'eyeball' the thing. you can figure it out. Most likely will use a 3/8 bolt,but not necessarily. Could be a head bolt or something else.Or,maybe the one you have is the wrong one....
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
