Company Logo Shop Now
Sediment bowl gasket cross reference
YooperJD60
07-17-2018 08:04:39
I need a 2" sediment bowl gasket, IH part number is A11208. Local NAPA store says they can't cross that number.Is there a comparable gasket that I can use?
BarnyardEngineering
07-18-2018 11:00:19
 Re: Sediment bowl gasket cross reference in reply to YooperJD60, 07-17-2018 08:04:39
It's not their fault if you give them bad information.
donald in mn
07-18-2018 07:51:05
I only use cork this modern gas destroys the rubber ones to fast
brownie450
07-18-2018 04:07:55
Hate to say, but Deere has bowl gaskets made of cork
yet. Believe they were $1.65 or thereabouts. They
are thick enough to take up the minor differences
on the base.
O'reillys local didn't know what I was talking about,
& couldn't find #398 on their computer.
Absolutely useless.
Jim
rustred
07-17-2018 16:50:42
some of those parts people are so useless. i buy my gaskets at peavy mart in a package of about 20 gaskets for around 20.00. anytime i need a gasket i have lots on hand.
moll
07-17-2018 16:14:35
I cut my own out of cork material left over from making valve cover gaskets.
ih560
07-17-2018 10:36:47
I done a quick search and got these napa part numbers
IH 360679R1 Fuel Sediment Bowl Gasket NAPA 730-9506
IH 49923D Fuel Sediment Bowl Screen NAPA 730-2373
gene bender
07-17-2018 08:55:12
get a new screen with it and they will have the rite size cause I just got one
YooperJD60
07-17-2018 10:28:12
 Re: Sediment bowl gasket cross reference in reply to gene bender, 07-17-2018 08:55:12
Would you have a part number? Where did you get it at?
old
07-17-2018 12:08:23
 Re: Sediment bowl gasket cross reference in reply to YooperJD60, 07-17-2018 10:28:12
O'Reilly's part number for the fuel strainer gasket is #398. I keep a few on hand and have 2 sitting here on my desk
gene bender
07-17-2018 10:45:44
NAPA take your bowl along so you get the rite size mine came with screen and rubber gasket. Check your main assy to make sure it isnt warped cause if it is you need to replace it easy to check just put the bowl in and see if it "rocks'
K-Mo
07-18-2018 03:48:59
 Re: Sediment bowl gasket cross reference in reply to gene bender, 07-17-2018 10:45:44
Yes Gene, a warped assembly is very common. Also, tighter isn't always better. That's how they get warped.
I don't know what NAPA sells now, but I quit buying their black rubber gaskets. The black gaskets don't tolerate much imperfection in the mating surfaces.
I use only the rubberized cork. The softer material can seal minor warpage.
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
Latest Ad: Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
