Company Logo Shop Now
M govenor throttle shaft rebuild
Fred47m
07-08-2018 17:48:23
This new project m It runs, but there is alot of tension when pulling throttle lever with tractor off. Throttle will only move six teeth. It actually snaps back on its own after it starts Almost like its got too stiff spring. Spring is identical to other m and spare governor. So i am thinking binding up govenor throttle shaft??? I have tried all adjustments mentioned in IandT and blue ribbon manuals. Also followed screw tightening sequence. Govenor works good otherwise. Kicks in good. So my plan was to get a gov to carb shaft rebuilt kit. Seems sloppier than on my spare. But it also wont idle down. So question is are my odds descent this will fix both problems? Dont want to just swap gov because then i wont know what the issue was! Thanks
tom dowling
07-08-2018 18:25:59
 Re: M govenor throttle shaft rebuild in reply to Fred47m, 07-08-2018 17:48:23
are you sure the tang is in the slot at the carb?
Fred47m
07-08-2018 20:07:10
 Re: M govenor throttle shaft rebuild in reply to tom dowling, 07-08-2018 18:25:59
I should be good with tab, i should have mentioned before but it was getting long, what is frustrating is that when i start up it will want to idle at estimate 600rpm, shut it off start hour later wants to idle at like 8-900. Back and forth like that. I feel good about carb. I am fairly experienced with those. I drive up slightest incline or have trailer gov seems to be functioning good. If i get that kit its about 50bucks for a bushing. So just hoping for ideas thanks!
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
