Company Logo Shop Now
SMTA not starting
Ellis Kinney
06-18-2018 15:30:42
This is one for the record books. SMTA with a 6 volt positive ground electronic ignition kit. It died on me the other day and I didn't have a chance to look at it until this afternoon. I fiddled with it and put in another ignition kit that I had from another tractor. Nothing worked. I noticed that when I cranked it the meter did not show discharge. I wondered if the meter was bad so I hit the light switch to see if it would discharge and it fired right up. The kill switch has no effect. Turn the lights off and it stops. Tomorrow I will try to figure it out. What happened. Ellis
Kalven
06-19-2018 05:03:51
 Re: SMTA not starting in reply to Ellis Kinney, 06-18-2018 15:30:42
Sounds like you have a bad ground in the dash. Remove the dash from the post and clean surfaces,also clean the back of dash cover where it goes on the housing. You can also use star lockwashers under the long screws that hold the cover to the housing.
Ellis Kinney
06-19-2018 07:28:25
 Re: SMTA not starting in reply to Kalven, 06-19-2018 05:03:51
The bolt that goes through the steering column was really rusty, I have cleaned the back of the switch case and will wire wheel the steering post. I didn't know the switch case had to be grounded. Thanks, Ellis
John M
06-19-2018 04:52:10
Something definitely isnt right. Regardless, disconnect the battery until you find the problem.
kevinj54
06-19-2018 04:26:55
Throwing parts at it is not the answer, could just be wiring or grounding issues.
55 50 ron
06-18-2018 19:21:30
The meter (assuming you mean ammeter) should not show discharge during cranking as starter current does not go through the ammeter. Normal ignition current would be barely visible on ammeter during cranking. That leads me to believe that maybe you have been seeing a heavy discharge on ammeter during cranking which, if so, certainly points to some serious wiring errors or faults.
Ellis Kinney
06-19-2018 04:42:05
 Re: SMTA not starting in reply to 55 50 ron, 06-18-2018 19:21:30
The ammeter does not show discharge when cranking, I thought it was supposed to, that is why I turned on the light switch to see if the battery discharged, and it started without pulling the starter lever. Ellis
55 50 ron
06-18-2018 19:13:35
That's quite ironic as I know of another SMTA (not mine) that has the same symptoms some times. It's like a ghost story!!
Ellis Kinney
06-19-2018 04:43:23
 Re: SMTA not starting in reply to 55 50 ron, 06-18-2018 19:13:35
How did he fix it?? Ellis
mattofvinings
06-18-2018 18:25:31
I would get behind the "dash" and look for loose wires, rubbed-thru wires, foreign material, or other obvious signs of damage.
It would appear that somehow one of the push-pull switch's connections was compromised to + or - (so it cannot complete the circuit), and the lighting switch instead supplied the missing pathway to complete the circuit.
Ellis Kinney
06-18-2018 19:10:10
 Re: SMTA not starting in reply to mattofvinings, 06-18-2018 18:25:31
Thanks, I am electrically challenged. I have a couple of extra kill switches. I'll look for worn wires and install a different switch. Ellis
Ellis Kinney
06-18-2018 17:52:15
Should I buy a new light switch and kill switch??? Ellis
kevinj54
06-18-2018 15:56:18
Find a wiring diagram & grab a volt meter, not a lot of stuff to check on one of these.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
