Company Logo Shop Now
What is this, and what does it do?
DougieD
06-11-2018 14:00:16
I've looked in my service manual and my operator's manual, and can't find anything about this. What is this? At first I thought Paul Bunyan comb, but now I'm thinking no. And what does it do? And where should I put it? Thanks.
third party image
DougieD
06-12-2018 19:43:14
 Re: What is this, and what does it do? in reply to DougieD, 06-11-2018 14:00:16
Good to know!
Eastsider
06-12-2018 19:38:29
third party image
When you have an extra one, they make a great custom anchor handle for a river anchor!
Mark (EC,IN)
06-12-2018 15:35:11
I think the reason you didn't find it in the tractors operators manual is that it had a manual of its own.
BarnyardEngineering
06-12-2018 04:26:27
You got lucky this time but next time please include the model of tractor that you're asking about.
It may still be useful in this case. The reason your manual may not go into the operation of the traction/draft control lever is because the hitch may not belong on that tractor. There were multiple designs for the fast hitch during the short time it was produced. Tractors made in 54-56 had a different style from tractors made in 57-62, and it changed yet again in 63.
DougieD
06-11-2018 17:51:29
Imsee. Thanks. So the higher the handle, the more traction.
The tractor vet
06-11-2018 17:33:27
It is what they called a TRACTION BOOSTER and some what of a draft control . You use it when pulling a fast hitch implement and it transfers the draft to add more of the pulling weight to the rear tires , For normal use you set it down to the last notch. If you notice you have tomuch wheel slip then you start to bring it up a notch at a time till you get the desired traction . When i had my 450D and pulling the semi mounts i usually ran it around two notches from the top or up possession , now one musdt watch as in hilol country she will lift the ft. easy going up the hills .
Charlie M
06-11-2018 14:38:52
I believe that adjusted the 2 point hitch on the 300, 350, 400, 450 tractors but I'm not sure exactly what it adjusted. I think it moved the hitch for traction control but maybe draft for mounted plows. I'm sure there are others that won't be guessing.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
Latest Ad: JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
