Re: H distributor in reply to Tbish, 06-07-2018 18:38:05
I've have an M and an A that broke teeth out of the timing gears. It stopped turning the distributor on the A, but it started as a slight knocking of the engine. As I was trying to pin point where it was coming from, the engine died and wouldn't start back. I realized the distributor was no longer turning and pulled it out and the governor gear had become damaged by the broken teeth on the other gears. I had to end up replacing the cam gear, governor gear, and crank gear.
On the M it was just the cam gear that had broken teeth and required replacing. Neither of these tractors had live hydraulic pumps.
If it's an IH "battery ignition unit" the odds are that the teeth on the distributor gear and the teeth on the little "pinion" that drives it have badly rusted and fretted and stripped 'cause few owners ever clean the old grease and moisture out of there and replace it with fresh grease.
Could be anything from the distributor 'drive',to broken timing gears. Pull the distributor and see if the drive lugs are turning,if not,pull the dist. drive Keep digging,you will find it.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
