Farmall M Radiator Removal - 2nd try
denglish
05-07-2018 12:03:46
Going to need to remove my radiator for repair. Any tips or tricks for removing the steering shaft that goes through the radiator?
Do I remove the shaft out the front after taking that big nut off? Any words of wisdom from the experienced would be appreciated.
denglish
05-08-2018 06:35:35
 Re: Farmall M Radiator Removal - 2nd try in reply to denglish, 05-07-2018 12:03:46
Thanks for the advice guys! It's one repair after another around here, but the good advice I get from YT sure does make things easier.
kevinj54
05-07-2018 12:13:05
You pretty much got it
denglish
05-07-2018 12:05:12
This is on a 49 M. It looks like I can separate the shaft at the u-joint under the hood and then pull it out the front.
John M
05-07-2018 15:56:48
 Re: Farmall M Radiator Removal - 2nd try in reply to denglish, 05-07-2018 12:05:12
Don't lose the thick washer where the bolt goes through the coupler.
old
05-07-2018 12:14:54
Yep take the steering loss at the U-joint and take the bug nut looking part off the front and the shaft just sort of unscrews out the front. The fun part is getting up under it and taking the bolts loss that hold it on
