Company Logo Shop Now
Farmall M PTO
Undertaker6378
04-14-2018 06:40:28
Was bushogging, hit a tough spot, and pto stopped working. No noise just quit. Still drives in all gears, dropped belly pump and bottom shafts still turns, what are the possibilities with this failure. Thanks
Goose
04-14-2018 18:31:12
 Re: Farmall M PTO in reply to Undertaker6378, 04-14-2018 06:40:28
If it's the same as an H, it's simple enough to check out.
The PTO shaft inserts into a socket in the innards of the driveline, with a sleeve around the shaft that slides into some lugs into the driving gear. Just park the tractor with the front end lower so gear oil doesn't run out, remove the bolts, and pull the PTO assembly out. It helps to slip a piece of pipe over the outer shaft for more leverage when pulling it, 'cause the unit is "front heavy".
I never had the lugs go kaput, but I did have a shift sleeve break so it wouldn't shift.
Mesquite Bob
04-14-2018 15:47:28
My M will do that sometimes too, I stop, clutch and make sure the pull handle "notches" up...then it engages until the next time it pops out. Hope this helps. :)
John M
04-14-2018 14:55:55
Have you tried it since it quit working? Is there a sheer pin on the hog end of the shaft? Overrun coupler? How big a hog you pulling?
DeltaRed
04-14-2018 06:55:04
Pull the PTO out. See if the problem is in the coupler inside.
Today's Featured Article - ... [Read Article]
Latest Ad: I NEED A PC160 FOR JOHN DEERE 100 DISC LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
Binary file (standard input) matches
