Hi. Looking for a starter motor to get an RD-14A generator going. Guy I bought it off had it running using a starter off a td14 he had. I have an early Td18 which has a delco #113452 but it is very different. Was in visiting a fellow collector and noticed his UD18 was different. He loaned it to me and it fits perfect. It is a Delco 109106. That will get me going for now but I will have to give it back. Question is what else used this starter? Not many Td/UD18 or 14's where I am (New Zealand) so if they were used else where that might make it easier. Thanks. Cameron
Re: Delco starter motor in reply to C Clark, 04-09-2018 20:53:56
Thank you all for your comments. Checked the loan starter again but cant see another '1' at the beginning. That said I am sure your right and that there should be, therefore make it a 1109106 which as Jim showed would have come from a UD18 which it did. At least now I know what I am looking for. Thanks again
My IH parts catalog (from 1952) shows these starter numbers:
UD-14A and UD-20 1109108
UD-18A 1109106
They are direct drive starters. The only difference between these starter is the drive housing.
TD-14A 000710
TD-18A 000756
The numbers look wierd, wonder if they need a leading 1. They are gear reduction starters. The differences are the drive housing, commutator end frame, and a piece of insulation.
Another reference (1965) repeats the above, including T-14 and T-18 and adds:
TD-14A 1953-1956 1109014
TD-14A 1957-1958 1113340
TD-18A 1957-1958 1113339
TD-20 1958-1959 1113346
TD-20 1960-1962 1113368
I included the TD-20 stuff as the early UD-20 reference suggested it might be relevant.
Here is what my 1965 Wilson book says. 1944-52 12 volt TD14- TD14A #710 Wilson # STT707 1953 -56 12 volt TD14A #1109014 Wilson # STT707. In the application part of catalog STT707 is only used on TD14 and TD14A. The #710 is with the Delco numbers, Delco usually uses 7 numbers during this era. Catalog has separate listing for Prestolite/Autolte and Lucas. Don't have info for UD18.
TD 14 18 and 20 (IIRC) all used the same starter, the Power Units using the same engines might (or might not). If you have a broken or worn starter, having it remanufactured might be the most cost effective. Jim
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong.
... [Read Article]
Latest Ad:
Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938.
[More Ads]
