FARMALL A REAR RIM BOLTS
catmando
03-16-2001 06:12:44
I KNOW THAT THE BOLTS HAVE SQUARE HEADS BUT
HALF OF THE NUTS I TOOK OFF LAST NIGHT WERE
SQUARE AND THE OTHER HEX..... I NEED TO BUY
NEW NUTS AND NEED TO KNOW IF HEX OR SQUARE
ARE ORIGINAL....P.S. MAN WAS IT FUN TAKIN
ALL THESE WHEELS APART..I LOVED IT
glenshoe
03-19-2001 06:28:15
 Re: FARMALL A REAR RIM BOLTS in reply to catmando, 03-16-2001 06:12:44
Try this website. I ordered square head bolts from them in several sizes. Luckily, they had a location close to home, but they're all over the country. Link
Tom H
03-17-2001 17:03:19
Most any place that deals in fasteners should be able to provide these. I provide a 3/4x5 1/2 and a 3/4x6 to a gold mine and have no problem getting them. These are a grade 5 bolt also.
They also make something you can put on bolts so they will come off easier. It's called anti-seize and comes in different size containers. It also comes in different kinds;siver, copper,and a few others. For general use I recommend the silver. A little bottle will last a long time and it keeps if you keep the lid tight. If you don't have anti-seize most pipe dope will also work.
My .01 worth
Tom
kimk
03-16-2001 17:19:43
Square headed bolts ---bought some from a local industrial supply house. could probably order them from McMaster Carr.
tiny
03-16-2001 12:46:03
i had to find the bolts for mine i ended up going to the john deere dealer to get them they were the only ones that had any not at a bad price ether
mel
03-16-2001 10:13:22
I looked on ebay and those bolts are only grade 2 and only go up to 5/8".
Brent
03-16-2001 09:26:51
There is a fellow who sells square bolts on E-bay under the agricultureal parts category I believe. He sells them in 5 pound lots and you get to choose the bolt size and length. You could find it using the search function on E-bay.
F20II
03-16-2001 09:07:35
The nuts should be hex, the bolts should have square heads on them, this so they will not turn when you are tightening the nuts. It is very hard to find square headed nuts anymore so some people are using hex headed bolts in there place. Make for a real bad day if these hex bolts and nuts are rusted up, you almost have to cut them off with a torch or nut driver. There is a place that sells square headed bolts and someone listed them a little while back but forgot who there were. I may self look around the bone yards when I get to one or while ording a part from a bone yard ask them if the can ship me a few square headed bolts I may need. I have even welded points on the hex headed nuts to make square bolts & nuts.
big fred
03-16-2001 12:50:30
 Re: Re: FARMALL A REAR RIM BOLTS in reply to F20II, 03-16-2001 09:07:35
I used hex on my B, replacing the badly rusted hex bolts that were already there. I'm not a stickler for originality. I had no problem getting the rusted nuts off. I just jammed a couple big screwdrivers in the bolt pocket to keep the bolt from turning. If they do rust so bad they won't come off, you can always drill out the center of the bolt and break them off with a hammer. (I don't own a torch)
F20II
03-16-2001 09:04:30
wnybrian
03-16-2001 06:41:45
Boy, I must have done something wrong... I just had the rear wheels off my "A", it was anything but fun. As for the nuts, mine were all hex, but I'm not sure if they were original. They came off like they were originals. I'm having a hard time finding sq head bolts for replacement.
the tractor vet
03-16-2001 07:02:24
 Re: Re: FARMALL A REAR RIM BOLTS in reply to wnybrian, 03-16-2001 06:41:45
The nuts are hex the bolts you should be able to get from Case IH that is were we get them.
Tom
03-17-2001 18:35:10
 Re: Re: Re: FARMALL A REAR RIM BOLTS in reply to the tractor vet, 03-16-2001 07:02:24
Curious as to what size they are and what you had to pay for them.
Tom
