Weight of 1967 International 424?
Trisha Jackson
03-15-2001 17:49:29
My uncle has a 1967 International 424 and is planning to haul it to his new home but he needs to know the weight of the tractor first. Can any of you guys help? Thanks a lot in advance! if you don't know does anyone know where I might find out this info?
Trisha
John W.
03-16-2001 05:30:07
 Re: weight of 1967 International 424? in reply to Trisha Jackson, 03-15-2001 17:49:29
Trisha, shipping weight for a 424 was listed at 3650lbs. However, your uncle's could weigh considerably more if it has wheel weights or fluid ballast in the tires.
Haas
03-16-2001 04:23:05
Not sure of the weight. I would guess around 5000 lbs. I hauled the one I used to have on a 7700 lb gross weight trailer. That leaves around 6000 lbs for the weight of the tractor. I would not recommend a trailer smaller than that. You will need a trailer that has brakes.
