Farmall & IHC Tractors Discussion Forum |
1066 pto clutch
Author |
[Modern View] |
flhr62
03-19-2018 05:56:52
Need to replace the clutch pac. Tractor will be used to pull a 15ft batwing. Should I go with the HD clutch or standard? Any recommendations on where to buy from?
Thanks
flhr62
03-19-2018 11:06:54
Re: 1066 pto clutch in reply to flhr62, 03-19-2018 05:56:52
i plan on getting the rest of it apart. Will probably replace everything. Have the fitting and gauge to check the pressure with
The tractor vet
03-19-2018 08:21:30
Yep , i use the HD clutch pac on all the PTO's . It does not matter where ya get the clutch pac's from , what matters is what kind of shape the rest of the PTo is in . Are the teflon seals good , is the center housing in good shape where the two seals ride , how are the brake pistons , is either rear seal leaking , is the pick up tube damaged does the seal leak , what is the clutch lock up pressures hot , . So inother words you would be wise to take it ALL apart and inspect and replace . IF you have never done one and have no idea then you maybe money ahead and have someone that Really and truely knows what he is doing and has the tools to do one along with the proper test fitting and gause to set the pressure when the system is at operating temps not first fire cold .
DeltaRed
03-19-2018 06:57:57
HeavyDuty..I'd buy from Joe at Redrunrite.Check out his website. Even has instructions to do the job.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Collection of a Lifetime - by Sherry Schaefer. The larest gathering of orphan tractors ever assembled by one collector will be auctioned off on May 15 in Rock Island, IL. Ed Spiess was a well known tractor buff who spent most of his time dreaming of rare and unknown tractors. His background as an agricultural engineer sparked his interest in the unique attributes of the models built from 1939-1959.
... [Read Article]
Latest Ad:
Need a clutch shaft for a 46 Massey Harris 101 Jr., F162 Continental engine. About 18.25 inches long, to fit 1-1/8x 10 spline clutch disk. Bare shaft without sprocket or bearing is OK.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
