Farmall & IHC Tractors Discussion Forum |
H4 magneto condensor to short to reach grounding screw
Author |
[Modern View] |
slydog
02-04-2018 13:28:47
I bought a points and condensor for an H4 magneto and the condensor is shorter than my old one and won't reach the grounding screw. What do I do now? Also is there a way to test my old condensor? Maybe it is ok and I can just use that and my problem will be solved.
Bob
02-04-2018 15:07:53
Re: H4 magneto condensor to short to reach grounding screw in reply to slydog, 02-04-2018 13:28:47
A "thermally-intermittant" coil certain can cause the issue you are having.
Just a warning, if you decide to replace the coil, don't get rough with the coil, trying to get it out of the old coil core. While the core LOOKS solid, it's actually laminated and easily damaged. Better to carefully cut the old coil off than to destroy the core.
Post back if you have questions, I have photos of a coil core that didn't survive, photobucket is holding them hostage, but I can find them on my 'puter and re-upload.
slydog
02-05-2018 10:29:17
Re: H4 magneto condensor to short to reach grounding screw in reply to Bob, 02-04-2018 15:07:53
How do you suggest I get the coil center out? Can I tap on it with a hammer and see if it will slide out? You say they are laminated? I have never had one out so not sure what it looks like.
Bob
02-05-2018 10:59:27
Re: H4 magneto condensor to short to reach grounding screw in reply to slydog, 02-05-2018 10:29:17
As I wrote previously, if the coil can't be pushed of the core easily but hand, it's better to carefully cut away the coil than to wreck the core. You don't want to destroy the core, last CIH list on D21314 core was $587.82!!!!
Here's what happens if you get rough with the core!
John T
02-04-2018 14:15:15
You ask " What do I do now?" A properly done short splice would work. "Also is there a way to test my old condenser" YES a true full fledged capacitor tester will work and if you're good with an old style analog ohm meter a "kickback" test can provide some degree (although not perfect or complete) of evidence of its condition. Basically if its always a total dead short its bad or if its completely open (IE no capacitor action whatsoever) its bad. Once charged a good condenser is an open circuit to further DC current flow, but when discharged it will initially accept current flow. There's a good chance an old condensor may be better then a new out of the box unit, give it a try. With no condenser in the circuit at all it can still fire albeit weaker plus the points will burn prematurely, but if its a dead short you get no fire at all. Try the old one n see what happens. John T
slydog
02-04-2018 14:50:53
Re: H4 magneto condensor to short to reach grounding screw in reply to John T, 02-04-2018 14:15:15
I robbed a condensor from another mag I had and it seems to work although I have spark it is pretty weak. I am thinking my next step is going to be replace the coil. FYI this mag is the one that would work great when the engine was cold but when it warmed up it would start to miss and sometimes even quit and the motor would stop. Then I couldn't get it started until the engine cooled down and then it would start right up. Would the coil be the cause of something like this?
John T
02-05-2018 04:58:44
Re: H4 magneto condensor to short to reach grounding screw in reply to slydog, 02-04-2018 14:50:53
Ignition problems that happen ONLY after she gets good n warm can possibly be coil or condenser related. Again if theres no condenser at all in the circuit or its weak she can still spark although its weaker and the points will burn sooner. Another problem can be points that are burned pitted and/or carboned, you might check that. Since a condensor is so much cheaper then a coil Id try that before a new coil. John T
old
02-04-2018 15:17:27
When the engine is running the coil does start to warm up and if it has a bad spot in the coils wires it will do just as your is doing so simple answer is yes your coil may well be getting bad
old
02-04-2018 13:51:10
Condensers almost never go bad but new ones are now likely to be bad from the get go. I have not change a condenser in well over 10 years now
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
Green magazine back issues for sale, in good used condition, some of the covers have mild chaffing. Have years 1991, 1992, 1993, 1994, 1995, 1999, 2000, 2001, 2004 and 2006 years available. 12 issues per year. 10 dollars plus shipping per year.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
