Company Logo Shop Now
TD-6 CRAWLER
henhawk
02-02-2018 22:28:22
I have a TD 6 crawler with a gas engine. Which Farmall tractor has the same engine. Is it the M or H or something else.
Gregthedc
02-05-2018 07:53:34
 Re: TD-6 CRAWLER in reply to henhawk, 02-02-2018 22:28:22
LIke the others it's a gas engine, I have one in my shop I just completed the restoration on. I don't have the original mechanical fuel pump, have an electric one mounted on firewall that works fine.
Dave H (MI)
02-03-2018 09:23:41
If I were you I would get the serial number and do a little research to see what tractor it actually is and what year it was made. If it turns out it is a T-6 then OK but if it is actually a TD-6 then you might want to have a second look at that engine because it should be a diesel. If it is gas then get the engine info and see what the engine is from. That will give you your answer. The TD-6 sitting out on my driveway right now has an engine that LOOKS like a gas engine if you are standing on the right side but move around to the left side and you find all the diesel components. Mine busted a connecting rod and I am going to go broke doing the repairs I bet. I don't much care about the money within reason. I just like to fix stuff. :)
RBoots
02-03-2018 17:52:31
 Re: TD-6 CRAWLER in reply to Dave H (MI), 02-03-2018 09:23:41
Dave, my offer still stands. Let me know when you're ready to work on it and I'll send you a rod and a piston. I only have 3-7/8" pistons though. I have a bunch of other D248 stuff too.
Dave H (MI)
02-04-2018 08:26:52
 Re: TD-6 CRAWLER in reply to RBoots, 02-03-2018 17:52:31
Thanks Ross! With all that goes on around here I had forgotten. I will put a copy of this in my folder for the TD-6 to help me remember. That tractor has been waiting for me to get to it for 5 years or more. Every year I would say that THIS was gonna be the year...then something hits the fan and I am off somewhere else. I have to winch it onto a trailer and take it to the farm this summer because I am looking to sell my house here. May take me a couple more years to get to it as I want to pour a floor in the shed before I put it in there and I am going to build a second house our there. Daughter has her eyes on the old farmhouse. As soon as I can get it into the equipment shed I will start looking at it more seriously.
Dennis K (WA)
02-03-2018 09:06:09
T6 with C248 also has a mechanical fuel pump that runs off the camshaft. The M engine does not have that available in the block. An electric pump could be used instead I suppose.
Dennis
The tractor vet
02-03-2018 08:42:21
Depending on the year will dictate what engine , Now if it is a diesel if it was made before say 53 /52 it would be a 248 cu in engine and when the super M's came out with the bigger engine then it would be the 264 engine , Now the old 248 could have been rebuilt to the 264 cu. in. , Now if it was a 264 and had been rebuilt it now could be the same as came in the 450 tractors and is now a 281 Cu in. engine . But if it is a late model TD 6 it will have the same engine as the 460-560 tractors now as to the Cu. in . on them i am not sure as i am not into the crawlers and shy away from working on them because i had my fill in my youth working on heavy equipment . So on the late ones it could be the 236 or the 282 .
old
02-03-2018 07:28:29
TD 6 is a gas over diesel engine unit so you do not have a TD-6 you have a T-6. As said same as an M engine. The TD-6 same as the MD engine
Cory Schmidt
02-03-2018 06:28:49
M or W6...we put an engine out of a w6 in our T6. if looking to swap out... need the crawlers mounting plates/brackets, oil pan and pump(crawler has extra baffle and pick up), and governor/ throttle linkage. I think that's all.
oldiron29
02-03-2018 05:48:16
M would be gas! MD would be diesel!
gene bender
02-03-2018 03:06:11
The "M"
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: POWER BLOCK KIT for John Deere 50, complete with pistons pins and rings new never used. trades welcome. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
