Radiator hose on H
Ben Gittus
03-13-2001 19:28:43
Does anyone know if you can get a one piece radiator hose for an H. I need the hose that goes from the bottom of radiator into water pump. Right now i have the 2 piece rubber hose with metal hose in center. I am having trouble with leakage, just wondering if anyone has replaced with a one piece hose.
Thanks for your help.
Farmer Bob
03-13-2001 21:27:03
 Re: Radiator hose on H in reply to Ben Gittus, 03-13-2001 19:28:43
Ben, If you're not concerned about originality, you can get a 13" long 1-1/2" I.D. flex radiator hose from Napa. Got one on one of my H's and works great.//FB
Bill C
03-13-2001 19:48:33
Just wondering. Do you have the clamps tight,and if so,are they in good shape?Is the rubber hose rotted,or split?Is there a hole corroded in the metal pipe?If clamps are good,rubber hose is still in good shape,and,pipe isn't corroded it shouldn't leak.It would probably be easier to repair/replace the problem than to hunt a different hose,plus,your H will keep it's nostalgic charm.The hoses on my 51 H are originals(I'm guessing)and don't leak a drop.
