504 gas gasket?
Youngin
01-18-2018 10:32:31
third party image
Ok I hope the picture posts. Where do these go?
Thanks,
AG in IN
01-19-2018 11:28:41
 Re: 504 gas gasket? in reply to Youngin, 01-18-2018 10:32:31
I didn't explain it very well. I hope this helps.
At the front and back of the block are little plates underneath the crankshaft. I'm sure my terminology isn't right, but I've always called them bridge plates. They are like a bridge, or, like bridgework in dentistry filling a gap. These little tab gaskets go between the corners of these bridge plates and the block. There may be some round felt or rubber pieces that go in the corners of these plates, too. On the back, the bottom of your rear main seal housing also bolts to the bridge plate. The pan bolts to the block, and to these bridge plates.
AG
AG in IN
01-18-2018 16:34:19
Front and rear crank seal plates use these gaskets.
AG
Youngin
01-19-2018 09:56:53
 Re: 504 gas gasket? in reply to AG in IN, 01-18-2018 16:34:19
Thanks, I can't see where, but i see I removed them. The oil pan gasket is continuous as is the rear main. I don't see how they would of went on the two pieces that connect the main's seals and oil pan. I bet I figure it out when it leaks.
