Muffler Recommendation
Johnnykick
12-24-2017 14:22:28
I'm fixing up a 1955 International 100 (industrial) as close to period as I can without breaking the bank. I've searched around for muffler and cap and there are several aftermarket makes with different metal finishes. Prices are across the board. Suggestions on type and vendor recommendation appreciated. I've noted that some folks finish off their restoration projects with chrome. Good idea/bad idea? Thanks.
BarnyardEngineering
12-26-2017 05:09:03
 Re: Muffler Recommendation in reply to Johnnykick, 12-24-2017 14:22:28
You don't. You get a generic Cherry Bomb muffler with the correct inlet size for your exhaust pipe, or cobble up something to make one that's "close" fit.
It's not a tractor muffler. It's a car muffler and looks like a car muffler stuck on a tractor.
The Stanley muffler is fine (IH-3 is the model number), and you can get them fairly reasonable ($40) at Tractor Supply or slightly less online ($25+shipping). Next step up is the "restoration quality" muffler in plain steel.
Super A
12-25-2017 06:38:50
By all means, the "restoration quality" mufflers from Steiner or similar with the IH emblem on the side. They are made from the original IH blueprints and look and sound right.....most aftermarkets have a 2" outlet which is not correct for the A--140 tractors.
Al
wgm
12-25-2017 00:55:20
I learned long ago that as the price of something goes down so down quality and longevity.
Johnnykick
12-24-2017 18:49:21
Sweet. Thanks.
Johnnykick
12-24-2017 18:12:11
Where would you go to get such a muffler for 1955 Farmall?
D beatty
12-25-2017 01:40:48
 Re: Muffler Recommendation in reply to Johnnykick, 12-24-2017 18:12:11
Stieners Tractor has restoration quality muffler with IH logo on it.
DeltaRed
12-24-2017 21:05:28
Here(YT);Stiener;FarmallParts.Com;TSC,other 'farm' stores..... ..
Phil Tibbetts
12-24-2017 17:49:08
I use the Cherry Bomb or straight through seamless mufflers. They will last practically forever and give the tractor a throaty but not loud sound. Plus they are very reasonably priced.
Johnnykick
12-24-2017 16:58:48
That was helpful. This tractor was apparently owned by a state or local government to mow grass. It didn't have lights which were also an option. It did not come with a muffler but a straight pipe with a small curve at the top. I suppose the straight pipe would have cooler sound than a muffler.
steve706
12-24-2017 15:34:32
On the original tractors, the muffler was an option. Chrome or stainless are pretty modern and are more for show than staying original. The standard grey finish is the closest to factory and are readily available from basically anyone who sells tractor parts including this site. Caps are personal preference, I have them on all my tractors just to keep the elements out if left outside.
Janicholson
12-24-2017 15:27:59
The Muffler from this site, or Steiners seem OK the Stanley mufflers look correct, but are louder. If you can see through it end to end, it will be loud. Jim
DeltaRed
12-24-2017 18:39:49
 Re: Muffler Recommendation in reply to Janicholson, 12-24-2017 15:27:59
I like "loud". LOL The SuperM has a Stanley. sounds GREAT! The 400 has a factory original IH muffler. Too quiet.The 1256 has a straight pipe,the 1456 may soon get it's muffler replaced with a straight pipe as well....Btw,My old 1970 Ford still has the (burned out) 'glass pacs'. Love em!(so do the neighbors) LOL
Janicholson
12-24-2017 19:06:17
 Re: Muffler Recommendation in reply to DeltaRed, 12-24-2017 18:39:49
I can't here you come closer. Jim
