100 Axle Seal Replacement
rnicholas
12-24-2017 05:34:56
Merry Christmas everyone. Okay, I've removed the nut from the axle on the inside of the wheel housing but when I try to pull the axle it won't move. Even using a hammer on the axle hub it won't budge. I haven't removed the housing oil pan yet but I was going to see if the axle would move before I did that task. So, what am I missing? Do I need to use more force?
third party image
BarnyardEngineering
12-26-2017 04:56:54
 Re: 100 Axle Seal Replacement in reply to rnicholas, 12-24-2017 05:34:56
You'll see when you get the axle out. I believe the bearing on the hub end of the axle is pressed on.
AlinMO
12-24-2017 12:33:30
Here is link to Case/IH parts web site of Farmall 100. Link
hendrik
12-24-2017 07:46:21
You need to pull the bearing and seal retainer on the other side of the drop box.. This retainer keeps the axle assembly in place.
rnicholas
12-24-2017 12:19:26
 Re: 100 Axle Seal Replacement in reply to hendrik, 12-24-2017 07:46:21
"other side of the drop box" What/where is the drop box? From this side of the wheel housing I can see a set of bearings. Are you saying there's a retainer on the other side of these bearings? I don't have an exploded view to refer to.
hendrik
12-25-2017 11:13:52
 Re: 100 Axle Seal Replacement in reply to rnicholas, 12-24-2017 12:19:26
OK drop box is wheel housing. The retainer is item 29 in the final drive shown in the link provided by alinmo. It is on the wheel side of your wheel housing; to the right in the photo you showed. The retainer is approximately 3 inch square
khouse6
12-24-2017 06:58:54
that is the stub axle. there is a gear on it.
rnicholas
12-24-2017 12:22:49
 Re: 100 Axle Seal Replacement in reply to khouse6, 12-24-2017 06:58:54
"stub axel" Are you saying the axel is in two pieces? I thought it was one axel that went all the way through the wheel housing. Yes? No? I really need and exploded view because I'm confused.
khouse6
12-24-2017 15:38:07
 Re: 100 Axle Seal Replacement in reply to rnicholas, 12-24-2017 12:22:49
folks use different words for parts. drop box is final drive is the portion that you are working on. farmall does not call this a stub axle, but some do. if you get the axle out, the pan will have to come off , before you can replace. friend of mine calls this portion drop axle and so do i. good luck
rnicholas
12-25-2017 16:38:24
 Re: 100 Axle Seal Replacement in reply to khouse6, 12-24-2017 15:38:07
I swear, this is a lot of trouble just to keep a little oil off the floor. Someone mentioned that the bearings had to be pressed on but I don't see it. Where in this assembly would bearing be pressed on?
