Company Logo Shop Now
Farmall 706 PS hydraulic lines
W6tractor
12-22-2017 12:48:22
The hydraulic lines in the steering column under the hand pump are leaking at or near the couplings in the steering column (not at the hand pump couplings). Itís leaking in the area of item 17 in the parts diagram. What is the best way to remove the hydraulic lines from the Mcv to the hand pump to repair or replace them? Thanks.
W6tractor
12-30-2017 07:27:38
 Re: Farmall 706 PS hydraulic lines in reply to W6tractor, 12-22-2017 12:48:22
Thank you for the response. Finally got it done. There are two access panels to get to the lines. Took the fittings off at the hand pump, but had to disassemble each section and reassemble by section to reinstall. Too hard to line up fittings and make sure no cross threading without doing so. Hope to tighten up and test when weather gets better. Thanks again.
DeltaRed
12-22-2017 16:25:56
If a hole is rubbed you can braze it. If a crack at the fitting,replace. A hose may be adaptable in that location.They are tough. Get some right angle wrenches (maybe even bend or grind an existing wrench),stand on your head and get after it.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
