Company Logo Shop Now
F12 / F14 Generator Bracket
SadFarmall
12-05-2017 02:16:10
I am certain this has been discussed before, but I would love to get hold of 3999DAX Crankcase Water Inlet Elbow (Delco-Remy Electric Lighting & Starting (Special) for F12 tractors. Failing that, a good picture of it; I know an engineer who would make patterns for it… Probably not a financially sensible thing to do, but using an F12 on the farm is enjoyable - not in a hurry to get from one field to another most days!
Any help appreciated.
SadFarmall
DeltaRed
12-05-2017 06:38:09
 Re: F12 / F14 Generator Bracket in reply to SadFarmall, 12-05-2017 02:16:10
There used to be an outfit in southDacota that made those and several other f12/14 parts. James Dove,Dove Manufactureing& Machine. I have no idea if they are still in business,or not.Good luck.
oldiron29
12-05-2017 08:09:03
 Re: F12 / F14 Generator Bracket in reply to DeltaRed, 12-05-2017 06:38:09
https://www.ebay.com/itm/International-Harvester-McCormick-Deering-Farmall-F12-F14/172919287686?hash=item2842caef86:g:hAsAAOSw2DFZuF0T
Dove is in Columba Station Ohio, James I believe has passed and his son David is selling off his thinks. Link above is dove selling on EBay.
Not sure if he has any elbows.
SadFarmall
12-05-2017 04:22:01
Thank you Sir!
oldiron29
12-05-2017 04:18:07
SAD, I have three electrics, I don't know how good the picture would be with the Generator on the bracket.
I will try in the next couple days.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
Latest Ad: JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
