Company Logo Shop Now
806 load control
Bob21 Martin
11-08-2017 15:05:47
Can someone tell me what the load control on an 806 does and how to use it.
I have the service manual, but not the owners manual.
Thanks a lot, Bob
pete 23
11-13-2017 10:54:50
 Re: 806 load control in reply to Bob21 Martin, 11-08-2017 15:05:47
I realize this is way late and may not be noticed if using classic view, but I failed to give some more important instructions on using the draft control. You adjust the knob down in action control range so that when you put position control lever down it will stop at your preset spot for action of hitch. Then you raise and lower the implement using the position control lever. When lowering, stop position control lever at the offset until implement is in the ground and then push farther to preset position. That way the implement will lower at full speed and you will not be disturbing the load control lever setting you selected earlier for the depth of your implement. You can also, under certain conditions, use the position control lever to limit the maximum depth the implement will travel in light draft conditions but then you will not have action control settings as it will be full speed lift and drop.
Bob21 Martin
11-15-2017 07:45:52
 Re: 806 load control in reply to pete 23, 11-13-2017 10:54:50
Thanks for the additional information, Pete.
Appreciate the help, as always, Bob.
pete 23
11-09-2017 10:30:20
Draft control, commonly referred to as the cheater control. It is used on implements that are hooked to the three point hitch and operate below the ground surface, like moldboard plows, mounted field cultivators and chisel plows. When using the draft control, you adjust the depth of the implement using the draft control lever. Once you get it set the depth you want to operate, you then adjust the speed that the hitch responds to a change in the draft (how hard implement is to pull). You do this with the position control lever by moving the position control lever down into the very lower offset section of the quadrant. There is an off set on quadrant that , if levers are properly adjusted (which very few are now days with everybody and his brother working on the tractors) the farther you go into that action control, (speed of raise control) the slower the hitch will respond to a change in load. It does this by bypassing a portion of the oil from pump when hitch calls for a raise of hitch.
You attempt to adjust the action control so that the engine maintains constant RPM's. In other words, when you hit a tough spot, the hitch raises some to reduce the pull on the tractor. If you set it too fast, the hitch will be constantly adjusting and jerking up and down. Too slow and engine will start to pull down.
It works good on uneven ground where the front end of tractor goes up and down over the terrain a lot. On those occasions, the draft control will actually keep a much evener depth of implement than a set point using positon control. On flat ground, with varying soil conditions, the raising and lowering of the hitch will cause uneven depth. That is why very few ever use draft control in this part of the country.
For normal three point work you put the draft control ALL the way forward so it is locked out. I always felt and still do that it should be an option on three point hitch. If you left out all those torsion bars and internal linkages a customer would have a lot less problems especially when tractor ages. The new tractors use a electronic lower hitch pin that is very expensive and trouble some. After market mfgs come up with by pass kits and plain old pins to replace them. I think that would be an option mfgs would offer.
Bob21 Martin
11-09-2017 12:17:55
 Re: 806 load control in reply to pete 23, 11-09-2017 10:30:20
I get the idea, now. Thanks for all the time you spent with that great description, Pete.
I'm using the 806 on a subsoiler I put together and running about 36 inches deep. I've had to fool with the control lever a lot to hold it steady with everything it hits down there. I have some bottom ground and hillsides. The hills have some clay and rocks that jerk things around.
It sounds like if I can get this set right the hitch will respond to what the bit hits.
Really appreciate the help,Pete
Thanks, Bob
ejr-Ia.
11-09-2017 08:53:50
It is the draft control for the 3pt or fasthitch it senses the draft or load on the hitch to much it will raise the implement.
Bob21 Martin
11-09-2017 12:20:14
 Re: 806 load control in reply to ejr-Ia., 11-09-2017 08:53:50
Thanks ejr for the response and information. I'll work on this setting and see if I can get it to go like they built to work.
Thanks, Bob
FastFarmall
11-09-2017 03:44:30
Not sure what u mean, engine load, or hydraulic load control,please explain further ?
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: 1953 Ford Jubilee SN#70068. I can provide pictures upon request and please only serious inquiries for the tractor. This tractor has been well kept under a shed. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
