I'm thinking about trying this combination for pasture clipping and perhaps field use. I'm on moderately hilly ground and wondering if I might be underpowered for this set up to work with out a bunch of headaches. If anyone has done this, I'd like your opinions please.
Re: Farmall C with a 7ft. 27V sickle bar combination? in reply to Dave O'Brien, 10-28-2017 15:09:03
We would cut alfalfa in 3rd gear with ours. Sharp sickle is needed.
27V is heavy on the SC. We broke the right rear axle housing on the SC with the mower on it one time, but had been mowing rough pasture with it. Good mower. Jim
I have been running one for over 7 years. I run along in 2nd gear at about 3/4 throttle. You have to remember you are not grinding it up like a rotary mower. You are just cutting it off. I have mowed weeds tractor high and pasture 3" tall all at the same speed. Just keep it in adjustment and sharp sections on it.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
